- Joined
- 21 May 2021
- Messages
- 2
- Reaction score
- 0
- Country
I have a strange one and can't find a solution or fix as of yet.
so...
1. I have a showerforce Turbo 2 pump which has a gravity fed hot water.
2. The cold water is mains fed and is not going through the pump.
When I switch the shower on the pump does not start automatically, when I pinch/squeeze the outlet pipe going to the shower the pump starts and works perfectly fine until the shower is switched off, once switched off it will not automatically start again and have to pinch/squeeze the pipe again to get it going. The outlet pipe connects to a check valve which is connected to the pipe which feeds the shower.
I am confused as to why the pump will not automatically start and unsure what to check, I would rather not be out the expense of a pump.
so...
