Hi, i just read the below text in the "fitting a shower" section on the site
Before fitting the pipes that will eventually supply the water to the shower system, it is important to cut off the water supply. In order to protect the pipes, they should be given a waterproof covering and also isolating valves should be fitted. The pipes can then be recessed into the wall and plastered over to neaten the overall look.
I am about to refit my bathroom and thought you could not bury the hot/cold pipes (that connect to the shower control unit) in the wall.
1) Please tell me if i thought wrong
2) Please can you suggest a waterproof covering that the above refers to
I have a combi system so will be mains fed...
thanks folks
thanks folks
