- Joined
- 24 May 2007
- Messages
- 9
- Reaction score
- 0
- Country
I have a problem with tiling and installing a shower tray. I took out the old ensuite and started putting in a new one. When I was putting in the shower tray a did notice that the cut away off the floor boards were a little weak, I didn't think it would matter too much and fitted the tray. I have since layed and tiled the floor up to the shower tray and now I am just about to start tanking the walls.
This moring I noticed some downward movement in the showertray and the floor around it. Basically, I think the cut open floor boards for the trap is dipping a little under weight. You can hear the creek when you step on the floor and a little be moreso when you step into the shower. I am not a little confused as what I should do . The shower tray is in and sealed and I can't see too much movement on the sealant (a really, really small amount, maybe).
It would be a nightmare to have to take out the tray and lift the floor, and even then I am not sure how I could fix the problem.
Does anyone have any suggestions, could I get away with the slight movement?
