My Porch is 1.8m wide. I have a second hand Velux which is 1140mm wide but of course flashing around will need space.. I have concrete verge tile and the roof is Marley concrete Modern (rough) tile. Would this Velux fit in that width of 330mm each side? Thanks.
Is the 1.8m external width or internal as you need to allow for the wall thickness too ? The width of a Modern is 330mm so will depend on your internal size.
