Side extension gable end inner block skin
7 Feb 2022
Hi All .building an extension myself and had some help getting to first floor the builders put down a wood wall plate then joists ontop. Then blocked on the plate up to top. Not seen this before. Inner block work sitting on wood
KR
Nick
No it definitely isn't right and should be changed asap.
Random, saying that because you're house was built like that is just conjecture.
Many thanks Gents much appreciatec
Should i cut out a small section of wall plate
A bit at a time and replace with block. So block surrounding joist all the way around
Hope you can help gents
Thanks for the web link
