I'm replacing my existing wooden side gate. I also intend to replace the batten or post. This is affixed to the garage wall and is the side on which the slide bolt keeper and latch receiver sit.
There are four bolts with square heads fixing the post to the garage wall. I'm assuming they're masonry bolts (though can't be certain till I take the post down). If they are, could I use same size masonry bolts in the same holes? Do I need to put larger bolts in? Or should I create new holes?
