how do i fit siemans rdj10rf to saunier duval f30e can it be fitted to the 2 wires that are connected by the link wire or do i need the plug to go onto the pcb
If I remember correctly the f30 has two terminal strips, lhs of pcb box. Connect one to common on Siemens receiver. L1 I think
Connect the other to switch live on Siemens. Lx I think
Check instructions.
Wire live and neutral as normal.
Use two separate wires. Think the switching side was low voltage.
Is it the old one or the condensate version?
The old one has terminal strip.
