I have ordered a number of siemens appliances and whilst a new kitchen is being fitted, the power points are being planned accordingly.
The hob has a max working load of around 7Kw so I intend to use the old cooker cable. ?? dont know the mm2??
The cooker has max work load of 3.5Kw which I thought was a little over top but then, if literature says then literature right. So then I thought that at least the microwave would fit on the new ring main. Noooooo, literature says that the max work load is 3.5Kw,
So my question is, do I run two new circuits to new kitchen (after new ring main and new lighting circuit), one for oven & hob, one for microwave, p.s. it is the siemens quantum speed oven OR WILL THE 3.5Kw UNITS BE OK RUNNING OFF THE RING MAIN??????
