HI, need some help with this dishwasher as its only 5 years old, loaded it as normal, then shortly it came up with check water supply fault. have manually check aquastop (connected to mains with safety block) works ok, no water in base of m/c, stripped and cleaned pressure chamber all ok, checked both micro switches on this and also the flood device ( red rod) checked solenoids next to this all ok. removed pump cover and this is clear. set m/c to run a cycle and connected my meter onto the aquastop terminals no power is being registered, and then m/c stops on check water fault, help..... what else do i need to check or what could it be?
thanks
thanks
