Do you hear a buzzing noise when it should be taking in water?
If so the anti flood has been activated. Numerous causes for this, blockages in the system pipework is the most common. Can also be faulty inlet valve, broken wiring, faulty timer etc.
Realistically you're probably going to need an engineer in to fully diagnose the problem.
