Siemens Electric Fan Oven - Display Flashing / Switching Constantly - HB131550B
20 Oct 2024
Any advice would be greatly appreciated on why the display on my Siemens Electric Fan Oven (HB131550B/01) is constantly flashing / resetting / switching (multiple times a second)?
The oven still works fine, it's just the display that is faulty.
Thanks in advance!
Our old oven would not work without setting clock which was playing up. I just took oven case off and swapped capacitors for high temperature ones, then clock worked fine for two weeks before playing up again. Capacitors dry out with oven heat. I ended up cutting in and out wires to the clock and joining up.
Oven worked for years after.
Have a look at capacitors or swap clock. You could also ignore or bypass it like I did
