Hi all
Wonder if you can help me.
I'm not getting any hot water from my CH system but the heating works fine. The 3 port valve (siemens MA-V322C) is not returning to the middle position. So when you switch the heating system off and reset everything, then remove the cover so that the spring returns the valve to the HW position then refit the cover and turned the water on only the valve stays where it is, then turn the heating on and it moves to the centre position. Switch the hot water off and the valve moves to the CH position, all fine. But when the hot water is switched back on the valve stay's where it is and won't move back to the middle position. I have to physicaly remove the cover, the spring returns it to the HW position then the motor moves it to the middle position. So basically it won't return once in the CH position.
Any thoughts on this would be greatly appreciated.
Regards
Steven
Regards
Steven
