I hope someone can help me with a bit of advice on the following, done plenty of searching and have an idea but a bit extra clarification would be great.
Situation:
I have a Siemens MA-V322C mid-position valve. I replaced the synchron motor a while ago but now it is not working. I believe the reason is the teeth on the cog which connects to the motor are worn. The motor is jumping as far as I can tell (clicking noise).
Ideally I would like to just replace the arm/cog but that does not seem to be a part I would be able to get hold of. Anyone have any suggestions on this?
Failing that I could replace the head, I have found one being sold but it's not clear whether the head is removable (not just the plastic cover and motor). I know the 'C' in the model may be important here but I'm not sure if that just means the motor and cover can be replaced. The other problem is that the "actuator" which I have found is more expensive than a new valve which seems like a false economy.
Last option is to replace the valve, I have read up on the method (isolate, bung etc) and am happy to do this. There is a Siemens CMV322 which is a direct swap so that sounds good. Is this a good valve? Honeywell seem to be recommended but the straight swap sounds good and the Siemens is a fair bit cheaper at around £40. If I decided to go for the Honeywell, how hard would it be to swap? Is there any reason why I should not go for the Siemens?
Hope this is not too long-winded and that someone can provide me with a little assistance.
Thanks in advance for any help.
Cheers
Neil
Situation:
Cheers
Neil
