Siemens tumble dryer problem
12 Feb 2009
Yorkshire
Hi my sister has a Siemens tumble dryer that will only work if you keep your finger on the start button. As soon as you take it off it stops.
I can't seem to find a relay on this machine. Will it be a Faulty start button.
The machine is about 10 years old and thankfully there is no fancy circuit boards on it!
If you post the model number you may be able to get specific help, normally tumble dryers have relays on to switch the circuitry. If I remember on some siemens it is in the base.
