Hi there,
I have a Siemens WM14E141GB washing machine also known as an e14.14. I believe it is similar to numerous Bosch models.
The machine stopped working a couple of days ago. It made a grinding/crackling noise when on a fast spin, and then stopped. The front panel has 3 lights flashing which the manual says means "motor fault".
The drum and motor rotate freely. The inside of the machine is coated with black dust. The motor was pretty hot and covered in lots of black dust.
Assuming that the motor was kaput and not wanting to just replace the brushes, I've put a new motor in, part number BSH144086. I've fitted it no problems, very easy.
BUT, the lights on the front are still flashing in the same pattern (top, middle and bottom of the 5 vertical lights) so still indicating a motor fault.
Is there something I need to reset within the machine to clear the fault code, or some other bit that needs replacing?
Some other Siemens washers appear to have a test or diagnostic mode of some sort which can be entered via a combination of button presses which can reset the error code - is that the case with this one and if so what is the button sequence?
Ta in advance for help.
Andy
Andy
