WXLM148AGB/19
Mrs was complaining washing coming out wet after the spin cycle,sucked out the xs water with wet vacuum,put into spin cycle and could see pump spinning away.
On the spin cycle the pump starts for a short while,starts spinning for a couple minutes,at what does not seem like the full 1400 rpm,then the programme ends,with washing still dripping wet.
Would this be caused by a faulty control power module??
update.just checked the rinse cycle and washer will not empty can hear pump spinning and the pump cover is hard to screw out due to the vacuum being caused so looks like a blockage somewhere!
