Following from this thread:
//www.diynot.com/forums/automotive-repairs/dealing-with-corrosion.351321/
I have started to strip the brakes down to replace the discs and pads. The Honda manual states that when pushing back the piston the hose should be clamped and the bleed nipple opened to avoid flipping the seals in the master cylinder. Nice idea, except for the fact the bleed nipple is seized solid. I have tried some Plus Gas but no joy. My usual method for seized nuts is the MAPP torch but with brake fluid being highly flammable and all this probably isn't a good idea.
Any other suggestions? I can't a socket and breaker bar on it either, could try a small bar I suppose.
Once I get it off is it ok to put some copper slip on the threads or is that likely to contaminate the fluid?
