Hi folks,
I've recently had my cellar lowered by about 10 inches and have had the floor tanked and the walls sand cemented with Sika-1. After this, the plumber has fitted some pipework against one of the walls (which has earth behind it) and I am seeing the area around it/below it to be quite damp. I am assuming this is because of the waterproof seal being penetrated.
Now that this "mistake" has occurred, what can be done to fix it? Do I have to remove the pipework and redo the entire affected wall with Sika or can I just carry out spot repairs where the screws/nail has been used?
After this has been corrected, any ideas on how you can connect pipes to the wall without penetrating the seal?
Thanks for the help
Thanks for the help
