sikkens waterbased satin
3 Nov 2008
Hertfordshire
Hi,can anyone tell me if sikkens bl satura is good to use on interior woodwork and can you use it with the bl primer over previously painted oil based paint after thourgh prep work many thanks
Yes you can and you don't need the bl primer, satin is self undercoating. the satura can sometimes split a bit on the first coat if prep isn't thorough. If it does give it a light rub down and apply the second coat, should be ok.
Cheers mate ,some of the timber will be bare so I'll just use the primer on these bits
