Silestone mounting question
27 Oct 2024
Hi there
Not really DIY I'm afraid but I wanted to ask if anyone can confirm how silestone worktops should be mounted to a kitchen unit.
Are they glued?
Reason I ask is I've had a worktop fitted and it seems a little loose. Fitters say it is fine. The issue I think is its only glued to the tops of the unit sides, not to a solid base - is that correct ?
I feel like if I pulled hard enough it would lift up. In fact one corner does move a little.
Any advice appreciated
Brian
