Silicone removal
14 May 2013
Hampshire
Hi! What is the best way to remove old white silicone off an acrylic bath edge in order to replace with new silicone? Thanks
Gently cut it off with a knife/Scraper and use Paint Brush Cleaner on a bit of rag with plenty of elbow grease,
The Paint brush cleaner can also be used to remove the grease and grime that gets on an acrylic bath and washed off using warm water.
I am not sure how the Silicone remover would affect the Acrylic
WD40. I just had to do this with a steel bath. Spray WD40 to soften it, scrape/peel off, repeat as necessary. It doesn't take all the work out of it but makes it a lot easier.
Cheers
Richard
CT1 Multisolve is very good once you have cut off as much as you can manually - costs about £7.50 a can and my first one has lasted for several bathrooms with no signs of running out yet - left me wondering why I bought 6 of the things !
Whichever product you use it is still going to involve a lot of tedious hard work and mild to moderate language.
