Hello all,
I was sure that I would find an answer to this on the web somewhere (quite possibly on this site). However, so far I have not.
Silicone sealant is nowadays used universally to seal around uPVC doors, windows, etc. However, certainly when I have used it, no matter how carefully I prepare the surface of the uPVC, after some months one can see that the silicone has become deadhered to the surface and there is a very narrow gap. This of course can let in moisture, which defeats the whole purpose of sealing it.
I always clean the uPVC with alcohol and then dry it before applying the silicone since I am sure that there is often a very thin layer of grease or something else on the uPVC surface. However, despite the silicone sticking well initially and showing no sign at all of having a problem adhering to the uPVC, after a few months careful examination shows a very small gap.
If this sounds like it is just me being inept, I would like to point out that the same issue has happened around many of the windows and doors in our house that were professionally fitted before we moved in (I think that they are Everest doors and windows).
Does anyone have a solution to this problem? I am wondering whether I need to roughen up the area that will be sealed using fine sand paper. Trouble with this is that if one is not careful one could damage the surface of the uPVC and shorten the life of the product.
Any thoughts / solutions most gratefully received.
Cheers,
Nick.
Cheers,
Nick.
