Might be a handy tool for finishing sealant (or might not, I haven't tried it) but that still misses many of the important parts of sealing your bath.
You don't want sealant down the back of the bath anyway, you want it sealed at the top where it touches the tiles, and you want a smooth bevel up from the bath top onto the wall so that water doesn't sit on it. A better sealant than the Unibond would be nice, but you might as well use it now that you've got it. If you have a heavily used bathroom you can always do it again when it goes black
So, the joint between the bath and the wall needs to be about 5mm. A little more or less is OK, but huge gaps will crack open and tiny gaps will split. Clean everything thoroughly and dry. Cut the right sized bevel on the sealant tube. This may be where most people go wrong. The right size bevel nicely fills the gap with enough bead to tool down cleanly without smearing all over but covering enough of both surfaces to adhere. Cut the nozzle on a 45 degree angle so you can hold the tube at that angle and apply the bead cleanly.
Fill the bath with water. Half full anyway. The idea is to make sure that the the gap is as wide as it is likely to be in use, as most baths shift or flex slightly. The sealant will be able to compress a little, but if it is stretched every time you take a bath then it will pull away from the bath or split. You might want to take off your shoes and socks!
Application is the simple bit, although a little practice helps with confidence. Applying in a smooth easy single stroke is best because adding more or touching up afterwards is messy. So apply a bead right along the joint. I apply moving towards my body, but I've seen people apply "pushing" the tube away from them. Looks weird to me, but I guess it must work. Once you've got a complete bead, tool it off. You can use a FUGI if you like, or a wet finger, or a plastic spoon handle, or a proper edging tool, or a plant label. Again, a single confident action is best. Fiddling about going over it again will just make a mess.
Leave the water in overnight so the sealant cures in that position.
