Hi everyone.
I am new to his site and not very technical with boilers/plumbing so please try and use full phrases rather then abbreviations, thanks.
Ok Firstly I had a problem with the boiler giving out luke warm water, I had a "home emergency" cover with barclays bank so I called them, they sent a engineer who looked no older then 24 who diagnosed the "Heat Exchanger" as being faulty and stated that before they replaced the part I needed a "Power Flush" of the system which was not covered in the policy (suprise suprise).
Anyway what I did was took out the "heat exchanger" myself and cleaned it and also replaced the "diaphram" which is inside the "Diverter Valve". When I put all the items back in the boiler would power up but I noticed the FAN was getting no power. The pump works fine and the Fuse in the PCB was also OK.
I followed the intructions in the boiler manual and it diagnosed that the PCB was faulty and needed to be replaced. I replaced the PCB and still no change, Fan was not getting power hence not working ( I used a electrical deivce to check if the component was getting power or not, forgot what its called).
So my problem is that the FAN will not work due to no power, Can anyone please help me as I have kids and have not got hot water or CH since Saturday 28th Feb 2011.
Also if someone know if the Engineer that came from barlclays was talking a load of tosh ref power flush.
Look forward in hearing your suggestions. Thanks.
