Sime boiler format 80c trouble
16 Jul 2013
Gwent
All ready posted one thread on this and was told to register to the combustion chamber part of the site and its either a very slow process or im just not getting a response so ill try again...
My boiler stopped working last night, the LED for the flame has turned red, when i try to ignite the boiler the fan and pump kick in and you can hear the ignition sparking for a few seconds before it stops and the LED turns red again.
When i turn the dial on the boiler to heating it doesn't even attempt to ignite, found the manual online which says;
"Red led on, ignition blocked/safety and smokes stats
tripped: turn the rotary switch in the position ( ) to restore functioning"
and that's it.
Before people start mentioning only getting it done by someone who is gas safe, I am Gas safe registered, but with little experience especially in fault finding and have been out of the job a while now due to redundancy not long after qualifying.
So I was wondering if anyone has had the same problem before I start spending money on potentially non need parts, any advice it greatly welcome and thanks in advance.
The advice will be given to you in the CC.
Repeatedly asking in the general forum is contrary to the spirit of the forum rules.
No one should be giving you that advice here.
Tony
