The problem with this Sime boiler is that it doesn't just out and out break down. It acts up.
The boiler runs fine for months then it starts acting up by cutting out and flashing green and orange or red. I am never sure which. I believe it is red and this means problem with the line post- condenser, whatever that is! It can be restarted quite easily again and carries on working ok for a period.
The ch engineer I get to repair it greases some arm (diverter valve?) that I believe functions in conjunction with the microswitch, then all is well for another 3 or so months. Could it be a faulty diverter valve?
I have searched the web and found that the microswitch (5191900) can be a problem, but surely this is not it, if the boiler works for a period after the above greasing treatment! Or is it?
I understand that there is condensate modification kit (5181620) for this model. The engineer checked that there was no blockage in the past, and again this does not correspond to the above successful grease treatment. So would this kit help? I can't find out the reason for the modification.
Incidentally the condensate goes directly down a plastic pipe and under the floor it does not pass directly through the wall to the outside. I therefore don't anticipate that it is freezing, although the boiler seems to act up around December/January each year. It has done it 3 times now over the past 4 years. I don't know if this is simply a coincidence.
It also seems to lose pressure slowly over a week or so. I have discovered one of the radiators is very slightly moist at the bleed point, not enough to even dampen the carpet below. Could this affect the pressure in a short space of time? I have tightened the bleed screw as much as possible but the moisture is still there. Perhaps I need to try and tighten the chrome hexagonal nut at the bleed point? I can find no other leaks.
Are there any Sime experts out there who can give advice? I find there are not many ch engineers knowledgeable about this boiler and its problems.
