Wall Hung boiler - seems to work fine but vibrates like crazy and is noisy. Even outside by the flue it is really load like a rattling noise. Pressure gauge shows 1.5bar and only needs topping up every 6 months by a little. Any thoughts gratefully received.
Last night the boiler totally stopped working. Just made a humming noise but no action under the hood. Mrs says its my fault and to fix it today !
called engineer this morning - theyre too busy to visit being inundated with loads of boiler problems it seems. Anyway i explained symptons and they said its probably the fan. Have just taken it apart given it a squirt of wd40 and it fires up now and seems to be working, but the fan is really noisy. Engineer said SIME went bust a few years back and the parts are hard to get hold of but i can see the fan is a SIFAN FFB - Hopefully I can still pick one of these up. Any good ideas to start me on my search ?
The engineer suggest replacement w/c 8th Jan with condensing boiler for £2k !!
The British firm selling Sime boilers was put into liquidation but almost immediately the itallian parent set up a subsidary but were hampered because the UK firm held onto the telphone numbers and web site.
