Help, my boiler has been OK for the past 7 years, but now the boiler will only fire up for about 10 to 15 seconds. when the heating comes on and is calling for heat, the boiler fires up but goes off after about 15 seconds, the pipes leaving the boiler are only warm even though the stat is set on 80. The same thing happens when you turn the hot tap on,one thing I have noticed is that the flow rate out of the tap increases when the boiler is playing up. This seems to be an intermittant fault, some part of the day it all works fine, the next its playing up again.
Can anyone throw any light on this, I'm pretty good on control circuits and basic plumbing as I'm a refrigeration engineer.
Cheers
Cheers
