I've checked the FAQ but one thing about this is eluding me about the problem I have with my Sime Friendly Format 80E water boiler.
The pressure's dropped to about 0.3-0.5 instead of the 1.0 it usually hovers around.
I have a filling loop to top it up, so was going to try that before calling an engineer, but it's been so long since I've needed to use it I've forgotten what to do next.
I've connected it up, but there's a nut or a screw near each connection that can be turned, but the nut by the connection where the pipe is hot just leaks water if I unscrew it, and the screw by the connection where the pipe is cold just won't turn. I thought that was the one I used to turn before but it's stiff as a board.
Thanks in advance, Dom
