Can anyone help, For some time their has been a noise like solenoid chatter when the heating is first turned on. Yesterday no heating when got up, made various checks and found an internal 1.6 fuse had blown. I replaced that and it fired up, with the chatter noise coming from the 24v input on the gas valve. If I remove one of the wires the noise stops but boiler flame is only on low heat. When system is hot, wire can be re-connected and boiler works properly. Is this likely to be the board, the gas valve, or a stat?
