So, it's been a while since elementary electronics and I now have an issue I desperately need to resolve other wise I'm going to have to rip through a wall.
I'm working on a project where I'm installing a USB based touch screen monitor (yes 100% USB based) that is situated 3m away from a PC. USB, if you're in the know delivers 5v along with the data connection and as expected over 3m it doesn't work too well, barely being able to power up the device. The device also comes with an additional 5v DC jack and AC adapter that one could use if extra power is required. I was able to forsee this, so along with the wall embedded USB cable, also pre-wired an additional (telephone grade) 2-core cable that takes 5v from a distribution panel and delivers it to the unit via a DC jack. The wiring from the distribution panel is about 5m in length if I am to include all the bends and twists.
Despite all this I cannot get the monitor to power up using this 3m USB lead + approx 5m of cable carrying the additional 5v DC. The voltage reading at the DC jack end is delivering a pure 5v and the distributor can deliver up to 3A (the unit requires 0.5).
However, using the same wall embedded USB lead and instead of using the distributor supplied 5v, if I plug in the supplied AC adapter into a socket near the unit (supplied AC adapter cable is 3m in length), it all works just fine. The supplied voltage coming from the AC adapter is identical to the voltage provided by my distributor (measured using a multimeter), although the max current from the adapter is about 1A.
Clearly the wall embedded 5v carrying cable is not able to deliver the same voltage/current as the AC adapter, but I find it difficult to believe that this is due to the additional 2m length. I have alarm cable running around the entire house in some cases delivering 5v and 12v up to 25m away!
So here's where I guess I'm demonstrating my ignorance. Using a multi-meter, why am I able to measure a pure and consistent 5v from the wall embedded power cable (exactly the same as the AC adapter)? What (and how do I measure it) can I do in order to determine why the wall embedded cable is not able to deliver the same voltage/current as the supplied AC adapter? Is there something I can do with a multi-meter?
Thanks for trying to understand my problem![/u]
