Simple shed.... Will this give me lots of grief?
7 Dec 2011
Sheffield
Hi there,
We have just bought a house & we have no plans to move, were about to to a major garden makeover part of which will be a shed..
The garden is quite sloped too just to add
Now i want a relatively solid affair ( its going to act as a workshop ) my thought of construction are as follows
sink sturdy fence posts into concrete pads ( probably 6 or 8 of them )
build a floor support / joists between the posts & board it
then put in any extra lateral supports for the sides / windows & shiplap up the spaces between the posts & pop a roof on
not seen any shed designs like this before & i wondered if I am about to embark on a large failure
Any thoughts?
Any timber sunk into the ground will eventually rot so if you expect it to last a considerable amount of time it will not.
you could use short concrete posts... i did a similar thing to you for my decking, and it worked ok !!
hmmm I like the idea of that....
also considering concreting in some fence posts mounted in those bolt on metal spikes ( or just driving in those bolt on metal spikes come to mention it ) then the wooden bit is above ground
If you are going to put wood in the ground stand them in a drum of creasote for a few days and put some water proofer in the concrete mix.
this is what i was on about http://www.diy.com/nav/garden/fenci...e-Concrete-Repair-Spur-H-1m-x-W-80mm-10086576
As for the hammer-in spikes, i'd steer clear... you only need to be 5 degrees out vertically and slightly twisted and you can't properly attach your joists. They're very difficult to get in accurately.
if you want the 'metpost' type (and other makes are available !!) fitting, then look at these
http://www.diy.com/nav/garden/fenci...ers/Metpost-Concrete-In-Red-75-x-75mm-9276635
But for me, metal can rust, and wood can rot.... but concrete will be there longer than you will ;) plus you can set it out neatly before it goes off.....
