I have just put in a butler sink and moved two separate kitchen taps from standard upright fittings (that were fixed through the worktop) to wall mounted ones.
I have two brass wall mounted elbows (that will be behind some t&g panelling), each has a 4" chrome extension pipe that gives enough clearance from the wall for the butler sink (this passes through the t&g), and finaly the taps are screwed on the front.
My problem is that when I screw in the extension and the tap, the tap screws in firmly to being horizontal (needing a quarter turn more ) - If i dont tighten the taps fully the joints leak, if I go for full tightening the extensions develop a leaky hairline crack. So far i have split two extension tubes by tightening this extra quarter turn, which involves considerable force. I have tried two different thicknesses of ptfe tape to try and get the taps to seat in the upright position, I have also tried using jointing compound (not together with the ptfe).
I give up! what is the clever trick that all you professional plumbers use to get a tap to seat in a conventional vertical position?
