Hi
My friend has an old Potterton Netaheat system boiler. It is controlled by a single 2 port valve meaning the hot water must be permenantly on. There is also no room stat just a timer control, pump and of course the heat setting on the boiler.
The valve packed up. For a short while it could be operated manually by the lever. Now that too has given up the ghost. The valve is at least 20 years old. In short plenty of hot water but no central heating.
The 5 wires on this valve are very similar to the standard valve wires today. Grey, brown, blue and earth are the same, with red instead of orange. The electrician he uses is not 100% with heating controls so my friend asked me 2 questions and I wasnt sure of the answer to either.
Firstly would a modern 2 port valve be interchangeable with the old one treating the orange wire as red.
Secondly, could the wires be simply removed and the 2 port valve be substituted for a manual gate valve. That wouldnt be my choice but I would be interested in the answer all the same.
