- Joined
- 21 Jul 2007
- Messages
- 237
- Reaction score
- 5
- Country
A single brick garage, the roof is supported by external floor joists (roughly 3.2mtrs in width).
The ends are exposed due to the garage being single brick.
One of the beams needed to be replaced, as the roof was leaking. It probably did not help that water could penetrate through the exposed ends.
Questions..
a) Can I cover the exposed ends of the beams?
b) If I can cover the ends, can I use Sand & Cement?
c) If Sand and Cement is not good enough, what else can I use?
A facia wont cut it, as the fascia will need to be huge...
Pictures may help..
Questions..
Pictures may help..
