Single course of bricks above window
21 Sep 2015
I’m currently replacing all of my windows (with BC sign off). So far all of my downstairs windows have had stone lintels on the inner leaf and angle iron on the outer leaf, but I’m now doing the landing and bathroom windows which go all the way up to ceiling height and I’ve found that these windows are all original wooden frames with one course of brickwork sat directly on the wooden frame on the outer leaf. This course of brick is not visible as it’s hidden by the soffit (the soffit is sealed against the top few mm of the window frame) and at the moment I don’t think they do anything structural at all (the inner leaf seems to support the wall plates and keep the rafters aligned).
Which course of action should I take? Do I need to fit angle iron or is this overkill?
No need for any external support, if there is no visible masonry above the windows.
We normally conceal a length of timber within the eaves space above the soffit, then fix the window head to it.
Thanks for the reply. I was hoping this might be the answer. The soffit is already fitted and it’s just sealed against the brickwork/frame. I think to give me options I’m going to get a 50mm top frame extender too.
