Hi All
By convention, with a normal two tap unit the left hand one is the hot supply.
But when you fit a single lever (ceramic) tap am I correct in my understanding that the hot flow should be controlled by moving the lever to the left.
The reason I ask is that I had such a basin tap fitted and the hot flow is vice versa i.e. I have to shift the lever to the right for the hot supply
I have looked at the 'pipe tails' from the tap and they are tagged red and blue (hot &cold) presumably by the manufacturer & tracing them back in the piping they are by that marking plumbed correctly BUT as I say above this seems the wrong way round.
Please check my understanding and set my mind at rest
