In my living room I currently have a single light which is controlled by a single switch.
I have put in a number of halogen lights which now all trigger off the single switch
I am looking to put some X10 control onto these lights such that there are two circuits: Circuit 1 controls 3 lights & Circuit 2 controls 2 lights.
I am more than happy about how to convert the single circuit to 2 with the X10 moules turning on the lights but I would also like the old light switch to still work i.e. flick the old light switch and it turns on both circuits
The bit I am struggling on is how to wire this is that if you put the switch to both circuits then it will cause a short on the X10 modules thus turning all lights on when either X10 circuit is switched on.
Is it just a case of using the switch to turn on relay triggered feeds (thus isolating each circuit? If so would some normal 240V 3A ones be OK? The only limitation with this is you could not have them dimmable.
Is there a way of doing this keeping the main dimmer with the capability of dimming all lights?
[2 Light Circuit = 100W]
[3 Light Circuit = 150W]
