Hello,
I renewed the wiring for the lights up in the attic; I moved the light switch from the attic to the cupboard and put a new three gang light switch. It’s basically rear outside lights, Attic lights and cupboard light where the RCD is located. Originally the light switch was wired up to a ceiling rose. All I have done is changed the ceiling rose for a 20A junction box with three rows of block connectors which makes 12 connections. All I have done it connected everything the same as you would in a ceiling rose connection, Switch Live is connected the same way as well. Press the light switch and the light on in the attic which is a bonus, but when you turn off it causes a short and trips the RCD. I am left scratching my head because it should work perfectly. If it tripped the lighting circuit I would understand it’s the lights causing the problem. But it’s tripping the RCD for that side of the fuse board. I should point out that I have a dual RCD fuse board it has three RCD’s the main one for the entire fuse board and the fuse board is split into two sections. The one where the lights are connected including a ring main trips when your turn the switch off. I didn’t do this before I changed it over to a junction box. If I had a Mega Meter I could find out what is causing the short, I’ve tested the circuit does open and close but I am not certain what is causing this to short out.
…Oh, all the switches are wired independently, the attic, cupboard and outside lights. The other witches for the cupboard light and the outside lights are fine it’s just that one switch for the attic lights. I was wondering if the 3 gang light switch is faulty… which something I haven’t tested yet is, I shall rewire the switch for the outside light and cupboard and see if this still happens. If it does then, I know it’s a fault with the switch. The original wiring was done when we purchased the house 17 years ago; it was all rewired by an approved electrician. Although, he wired the attic lights to a ceiling rose instead of a junction box for some reason. Maybe it was because it made it easier. I used a 20A because there are three cables and one switch live return.
Any thoughts on this problem would be gratefully appreciated because I’m out of options.
Thanks,
G
Thanks,
G
