hi all,
thanks for your help on a previous post which has helped me determine that my house has a single pipe system. i'm fitting new rads throughout and some of the older ones did not get hot (possibly they were on the end of the ring) and want some advice about this please.
1) having read a little about the piping of dual pipe systems it appears that the furthest rad with the longest piping from the boiler should have the shortest return pipe in order to balance the relative pressures to all rads. why does this apply if all rads have TRV's as surely adjustment of these would give the same result whilst significantly reducing the work involved in modifying the piping?
2) can i use the current single pipes to best effect for changing to dual piping and use microbore for all the returns as this will be much easier to slip through the current holes in joists etc?
3) where all the microbore returns meet is there a manifold i can buy which will simply join them all together and then into the large pipe which returns to the boiler?
4) the new TRV's expect a 15mm pipe. are there 15mm to microbore solder adaptors which i can fit under the floor boards?
5) does it sound like i don't know enough about what i trying to do???
many thanks
many thanks
