**SUBJECT SHOULD HAVE BEEN CLEARER - TRYING TO REMOVE 1 GANG 2 WAY SO LIGHT ONLY CONTROLLED BY DOUBLE POLE SWITCH**
Hello,
I have a Double Pole switch at DOOR 1 controlling two bars of GU10 LED Spots (4 on each bar). One bar is on an independent circuit which is working fine, but the other is also connected to a 1 GANG 2 WAY SWITCH at DOOR 2 which I want to remove. I took the wires off it, but the lamp connected to it using the Double Pole switch will then not light.
Here’s a wiring overview accounting for the lamp I am trying to resolve the issue with only.
DOOR 1 (DOUBLE POLE SWITCH)
N1: Red
N2: Blue
DOOR 2 (SWITCH TO BE REMOVED)
B: Yellow (separate cable)
B1: Yellow (same cable
as
B2)
B2: Blue (same cable as B1)
I’ll post a diagram as asked in due course. Thanks in advance.
Hello,
N1: Red
N2: Blue
as
B2)
