Single Rad comes on when computer says No.
29 Aug 2010
Gloucestershire
Hi Folks,
I have a really weird intermittent thing going on. It happened again last night.
I have 3 zones of UFH downstairs currently running 24/7. Upstairs I have 6 rads/towel rails on 5 zones (8 in total). All the rads have wi-fi controlled TRV's or 'Actuators'.
All rads are programmed to go off at 8pm. Last night, one of the rads (Zone 7 - Bed 2) stayed on all night. This is despite the controller telling me that all the rads were off and none were calling for heat.
All the equipment was supplied by a Polish company called TECH (they supply a company in the UK called PolyPipe which has been helpful supply user guides for me). The last time I had an issue with a sensor, they suggested I send it back to them in Poland so they could have a look at it. That would have meant no heating in that room for as long as it took.
I cannot figure out how one of the rads can come on. Is it a fault with the controller?
I'm getting to the point where I think it will be better to rip it all out and put something 'standard' in like manual TRV's and a Nest.
Thanks.
Mystified, confused and frustrated of Cirencester.
There can be downsides to using non mainstream brands...
Swap over one the working heads to find out.
My guess is that an actuator is more likely to fail (and easier to replace).
Thanks polesapart, if I can find the instructions on how to do it, I'll give it a go.
The only time the rad goes off, is when none of the other zones are calling for heat.
I turned off the zone completely at the controller but the rad was still getting hot.
This electronic stuff is great when it works.
