After some advice while I'm in the planning stages for my intended workshop / man-cave:
I'll be getting rid of the shed and replacing it with an (approx) 14ft x 11ft workshop. The plan is to cast a single section concrete base (a raft??) to the right size with a damp proof membrane underneath it, with a depth of about 20cm around the sides. The concrete base will be the workshop floor and not planning on installing a raised floor
Walls will be concrete blocks, which I'll clad in feather-edge timber to soften the look and make it look less like a bomb-shelter.
Height will be 2m at the back rising to just shy of 2.5m at the front
So - after some advice on the following if possible please:
1) Is a 75mm raft with an edge depth of 200mm sufficient?
2) Can I use dense concrete blocks or am I limited to the lightweight concrete blocks (my builders merchants - Doves - has them billed as "7N lightweight solid concrete blocks") - If I've got my numbers right it should be no more than 11 courses of block at one end, and as little as 8 at the other end
3) will lightweight blocks be ok holding up a tiled roof?
4) do I need to add reinforcement to the concrete?
