Dearest experts,
We're undergoing a garage conversion at home and the boss lady would like a 5m bifold door in one of the existing walls of an old oil tank room (lean to on the main garage)
The wall is single skin, 4 inch concrete block construction holding up a flat fibreglass roof (which will be replaced with the same but beefed up a bit). The original plan (agreed with my lovely building inspector) is to insulated externally and timber clad over.
My concerns are;
1) that's quite a span for such a large opening. A heavy I or C section steel can do it but it seems a bit.... wobbly to me
2) the windows would be attached to the inner skin rather than the normal outer skin. Is this going to look weird or more importantly work with cold bridging etc?
Thanks in advance
My concerns are;
Thanks in advance
