single skin external wall causing condensation/cold/damp!!!!
2 Aug 2009
I have been suffering from black spot mould for five years in a ground floor room with a single brick skin external wall. I have hacked the existing plaster off as it was suffering from salts and there is a chemical damp proof course in place from an established company. Air bricks are plenty beneath the timber joists and into cellar, I have also insulated between the joists to prevent cold coming up through the floor boards.
My intention was to line the wall with something? Maybe some sort of barrier that i can then dot and dab foil backed plaster board to this.
Will this be any good?
My limitations are if I have to use batterns etc then i will have to move the door way etc!!!! I have about 15/20mm to play with. any thoughts and solutions would be welcome?
hmmm. first thing to do is to establish why the damp? where's the source? this should be fixed first before throwing money at solutions to cover it up.
sounds like it's a constant problem if you're having efflorescence (salts) regularly, assuming damp proof course is fine, have you checked outside for a bridge of the DPC or a broken gutter etc?
probably not a cold a cold spot as this would only cause condensation and salts suggest water from the wall coming through, thistle dricoat plaster may be an option but this could cause a cold spot if it's an outside wall.
all really depends on the problem though which should be established if possible first.
