Hi Chaps,
The previous owners extended the back door out past an external cupboard, making a small area of the kitchen single-skin - the cupboard. It's bloody freezing, and whatever insulation they put in there was poorly done and ineffective; I'm going to rip it out and do it myself.
I was going to put some 50x50mm battens against the wall, then 50mm foam insulation, then a damp proof membrane, followed by foil-backed plasterboard.
But the wife wants shelves.
Can I put up 50x50mm battens, put 50mm insulation between, then add the membrane and board? I can only really afford to lose 100mm on the two walls.
If I went with the original plan, would I need to put in a couple of airbricks for the cavity. If I did the second, is the lack of a cavity likely to cause problems, and the battens transfer the cold too readily?
