I have planning permission to build a front porch with external dimensions of 2400mm x 2100mm. I am not allowed anything larger.
Building regs don't apply.
It will be built out of block and then externally rendered.
Now my question is should I build it single skin or build a standard cavity walled double skin with insulation?
The reason I ask this, is that the internal area inside is quite significantly larger if built single skin.
If double skin, the internal area of the porch is 3.24 square metres.
If single skinned, the internal area of the porch will be 4.4 square metres.
Am I being greedy?
Will damp be a big problem?
Is the extra area worth any disadvantages?
What do you think?
Cheers,
Bobby
Am I being greedy?
What do you think?
Cheers,
Bobby
