I have a 1900s brick terrace, painted peddle dash (before me), with a single skin section under the front bay window.
It's cracked, the airbricks need moving as they are below pavement level, the bricks are all spalled, it's only about 5ft wide, thinking of propping up the PVC window and rebuilding the single skin wall underneath. (it's only ground floor bay so it's not supporting more than the window)
We get condensation on the inside and I'd like to add some insulation.
As it will need rendering and painting to match, would you either use solid concrete block and add some internal insulation, either batten and insulate or use foam backed plasterboard? OR would you use Thermalite / aerated block and have the headache of trying to render it on the outside.
