Hi all,
Need to some serious help with this;
We purchased our property a couple of years back with three extensions
1x Rear single floor
1 x Front single floor
1 x Side - two floors - Which contains upstairs a bedroom, ensuite and downstairs a study and garage.
We are now looking at converting the garage into another room, however it has been brought to our attention that the garage and the study (downstairs) are only single skinned walls with intermittant pillars, yet the walls above within the ensuite and bedroom are double skinned i.e have a block cavity wall, with an outer single brick wall.
According to the plans there is a steel which has been placed across to support the upper cavity block wall, however upon looking up through the garage ceiling, only a wooden beam can be seen which is flush against the garage single skinned wall i.e. it would not be in-line which the cavity block wall above if it was supporting.?
These extension are all over ten years old and have had planning approval granted albeit that we have no building control certificates and there is indemnity insurance covering the works.
As you can imagine I have a copuple of questions:
1) Is it likely that although I cannot see the steel, that it is there and a wooden timber has been placed across for some other reason?
2) If we pursue with planning permission to convert the garage are the inspectors likely to want to check this element?
3) If this is the case and remedial works are required, can this be enforced?
4) If enforced is it likely that indeminity insurance will not pay out as we have approached the planning dept, albeit regarding new works within existing works?
As you will probably note I’m a novice on this subject.
Any help or advise would be appreciated.
