I'm going with a 10mm expansion gap around the room, but am currently starting at the door way as I want a full plank to start as you come in to the room - mainly for strength as it will get the most hammering!
The planks will run from left to right of the door way. I've cut the door jamb/architrave so the flooring fits nicely underneath - but for it to look nice under the architrave, and door frame there will be minimal expansion gap - is this going to be a problem, or do I need to cut away more around the bottom of the door jamb/architrave?
